Floating menu: Images not loading
Hallo Andreas,
updated from 4.530 to 4.543 and none my iFloating menu mages are displayed...
Could you check ?
Thx,
Christian
  • BetterTouchTool version: 4.543
Was this after the up and downgrades you had to do recently? If so, you might need to remove some files manually as the database state might now not automatically recoverable.
To do this:
1.) quit BTT
2.) then go to this folder: ~/Library/Application Support/BetterTouchTool (use Finder => Go => Go to Folder, make sure to include the ~)
3.) Best create a copy of this folder for backup purposes
4.) Delete all files that have version numbers greater than 4.530
5.) Start BTT again
Top, works !
Thx once more,
Christian
