Floating Menu: CHANGING TEXT COLOR
Be able to:
  • Select text
  • Hit Hotkey
  • Choose color from preset colors in a FLOATING MENU (eg. red, blue, green)
I'm sure it's easily done with preconfigured triggers like the "Paste Item With Format" option. Though that would require a different trigger to be made for each color. But wondering if there's a way to simply display 3–6 colors (as a color palette) to change the color of text.
(rtf or plain or txt... default Mac text editing)
