@Andreas_Hegenberg Could you please briefly explain what these options do? I don't see any difference whether 10 or 50 is entered there. And what exactly does “Per-key...” do? Thanks.
you won't need this unless you have a broken keyboard. They prevent very quick duplicate key presses that can happen especially with defective keyboards (usually only for specific keys).
I understand that, but when typing a text, should there be a noticeable difference between whether it says 1 or 100? And if so, which one?
Yes, if you e.g try to type aa that won't work (and won't work for longer time span if the number is higher). Enabling this for all keys usually doesn't make sense as it makes normal typing harder.
Okay, thanks. I'll play around with it. Maybe it can be used for something you didn't intend ![]()
