Thank you for the amazing application! I'm trying to set up my touch bar so that the F keys are shown for certain applications. I have basically created a bar which just holds 12 F keys which have the respective F keys as their action:
(I'm doing this within Aquatouch - but I don't think that matters).
However, I noticed that modifier keys are not respected when pressing these keys. (For example Ctrl+option+F10 just sends F10). I noticed that it appears possible to 'respect modifier keys' in the ESC entry:
Have you figured out how to do that?
I'm having this issue too.
In my case, I set the fn key to bring up the function keys, but when I use that with the modifier keys, only the Fx key is sent. the modifier keys are not registered.
