export_preset script not working
  • I have upgraded to alpha, the problem persists.
when I run the export_preset command, I get the following error:
519:620: execution error: BetterTouchTool got an error: "tigger" doesn’t understand the “export_preset” message. (-1708)
Macbook Air M1 standard, no external peripherals
  • Type of Mac: MacBook Air 2022 M1
  • macOS version: 12.6.6
  • BetterTouchTool version: 4.091 (2307)
This had been working fine until I did a reformat of my system, imported my old preset, and now it won't export this one.
What command are you using exactly?
This seems to work fine here in the current alpha:
	export_preset "PresetName" outputPath "~/Documents/test.bttpreset" comment "someComment" link "https://someLinkToShowWhenImporting" with includeSettings and compress
end tell
Oh interesting, I just upgraded to the latest alpha, now it works again! :smile:
v4.100 (2316)
