Executing Script
I use BTT and DevonThink 3.
I have assigned a gesture to execute a script for DevonThink 3.
It works BUT.
Why doesn't the script execute the first time? It seems to me that the first gesture gets lost.
I have to repeat the gesture(second time) so it executes, this happens whether DevonThink3 is active, not active, front , not front.
*This happens just ONCE. It happens again if I close DevonThink then reopen it.
Any reason why the first gesture doesn't work?
can you post the script? for BTT there is no difference in how it handles the script on first or second run (unless there is some bug)
Sorry I don't know how to post script here, but here it is.
Thank you.
Summary
use AppleScript version "2.4" -- Yosemite (10.10) or later
use scripting additions
(* SETUP REFERENCE
Sidebar
1 Navigate keystroke 1 using {option down, command down}
2 Reading List keystroke 2 using {option down, command down}
3 Import keystroke 3 using {option down, command down}
4 Extras keystroke 4 using {option down, command down}
View
5 as Icons keystroke 1 using {command down}
6 as List keystroke 2 using {command down}
7 as Columns keystroke 3 using {command down}
8 Cover Flow keystroke 4 using {command down}
Preview
9 None keystroke 5 using {command down}
10 Standard keystroke 6 using {command down}
11 Widescreen keystroke 7 using {command down}
InspectorBar
12 Generic keystroke 1 using {control down}
13 Custom keystroke 2 using {control down}
14 Annotations & Reminder keystroke 3 using {control down}
15 Table of Contents keystroke 4 using {control down}
16 Thumbnails keystroke 5 using {control down}
17 Properties keystroke "p" using {control down}
18 Annotations keystroke 6 using {control down}
19 Links keystroke 7 using {control down}
20 List keystroke 8 using {control down}
21 Clouds keystroke 9 using {control down}
22 See Also & Classify keystroke "s" using {control down}
23 Search keystroke "u" using {control down}
global theDisplayList, theIdxList, theNameList, theSeparatorList, theDBList, theFullList, theViewList
global hd1, hd2, hd3, hd4, hd5
global theDB, theDBID, theDBRoot, theDBSel
property labelView : false
property labelDB : false
property dbListOnly : true
set theDisplayList to {1, 3, 6, 7, 9, 10, 11, 12, 13}
set theSeparatorList to {2, 2, 3, 2}
activate application "DEVONthink 3"
tell application id "DNtp"
try
set {sym, len, align} to {"_", "25", "C"}
set theIdxList to {1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24}
set theNameList to {"Navigate", "Reading List", "Email and Import", "Extras", "Icons View", "List View", "Columns View", "Cover Flow", "None", "Standard", "Wideccreen", "Generic", "MD-CustomMD", "Annotations & Reminder", "Table of Contents", "Thumbnails", "Properties", "Annotations", "Links", "List", "Clouds", "See Also & Classify", "Search", "Documents-Only"}
--If no section title but only view-section seperator is wanted
set hd1 to { my setWrappingLine("", sym, len, align), ""}
set hd2 to { my setWrappingLine("", sym, len, align), ""}
set hd3 to { my setWrappingLine("", sym, len, align), ""}
set hd4 to { my setWrappingLine("", sym, len, align), ""}
set hd5 to { my setWrappingLine("", sym, len, align), ""}
-- if separator titles are wanted
--set hd1 to {my setWrappingLine("Sidebar", sym, len, align), ""}
--set hd2 to {my setWrappingLine("View", sym, len, align), ""}
--set hd3 to {my setWrappingLine("Preview", sym, len, align), ""}
--set hd4 to {my setWrappingLine("InspectorBar", sym, len, align), ""}
--set hd5 to {my setWrappingLine("Database", sym, len, align), ""}
set theDBList to my getDBList()
set theViewList to my prepareList(theDisplayList, theIdxList, theNameList, theSeparatorList)
if dbListOnly then
set theFullList to theDBList
else
set theFullList to theViewList & theDBList
end if
my selectActionFrList(theFullList)
activate
end try
end tell
script D
-- 5 viewer windows, 20 dbs each, item 1's item 1 is viewer window id, item 1's item 1 is eXist or Nonexist
property vws : {{"", "", {{"", "", {}, ""}, {"", "", {}, ""}, {"", "", {}, ""}, {"", "", {}, ""}, {"", "", {}, ""}, {"", "", {}, ""}, {"", "", {}, ""}, {"", "", {}, ""}, {"", "", {}, ""}, {"", "", {}, ""}, {"", "", {}, ""}, {"", "", {}, ""}, {"", "", {}, ""}, {"", "", {}, ""}, {"", "", {}, ""}, {"", "", {}, ""}, {"", "", {}, ""}, {"", "", {}, ""}, {"", "", {}, ""}, {"", "", {}, ""}}}, ¬
-- property vwdbs : {"", "", {{"", "", {}, ""}, {"", "", {}, ""}, {"", "", {}, ""}, {"", "", {}, ""}, {"", "", {}, ""}, {"", "", {}, ""}, {"", "", {}, ""}, {"", "", {}, ""}, {"", "", {}, ""}, {"", "", {}, ""}, {"", "", {}, ""}, {"", "", {}, ""}, {"", "", {}, ""}, {"", "", {}, ""}, {"", "", {}, ""}, {"", "", {}, ""}, {"", "", {}, ""}, {"", "", {}, ""}, {"", "", {}, ""}, {"", "", {}, ""}}}
end script
on getDBList()
local dbl, db, dbs, l -- all opened databases,database, current database selection
local theDB, theDBID, theDBRoot, theDBQuery
local vwdbs -- list contains all databases in current viewer window
local vids, vid -- all opned view windows, the id of current view window
set str to "ABCDEFGHIJKLMNOPQRSTUVWXYZ"
set {vids, dbl, l} to {{}, {}, {}}
set db to databases
repeat with each in db as list
set end of dbl to {name of each, id of each, uuid of each}
end repeat
set dbl to my sortLOLByItemIdex(dbl, 2)
set vid to id of viewer window 1
repeat with each in viewer windows
set end of vids to id of each
end repeat
repeat with i from 1 to length of D's vws
if ( item 1 of item i of D's vws) is not in vids then set ( item 2 of item i of D's vws) to ""
end repeat
set {vpos, vstatus, vwdbs} to my lolLookup(vid, 1, 2, D's vws)
if vpos = 0 then
set {vpos, vstatus, vwdbs} to my lolLookup("", 1, 2, D's vws)
set item 1 of vwdbs to vid
set item 2 of vwdbs to "A"
set dbs to item 3 of vwdbs
else
end if
repeat with i from 1 to length of dbl
set item 1 of item i of dbs to item 3 of item i of dbl
end repeat
set theDB to database of (root of think window 1)
set theDBID to id of theDB
set theDBRoot to uuid of (root of viewer window 1)
try
set theDBQuery to search query of viewer window 1
on error
set theDBQuery to ""
end try
if selection ≠ {} then
set theDBSel to item 1 of (selection as list )
else
set theDBSel to {}
end if
set item 2 of item theDBID of dbs to theDBRoot
set item 3 of item theDBID of dbs to theDBSel
try
set item 4 of item theDBID of dbs to theDBQuery
on error
set item 4 of item theDBID of dbs to ""
end try
if labelDB then
set (dbl's item i)'s item 1 to (str's text i) & " " & ((dbl's item i)'s item 1 as string )
end repeat
end if
if dbListOnly is false then
set beginning of dbl to hd5
end if
return dbl
end tell
end getDBList
on prepareList(theDisplayList, theIdxList, theNameList, theSeparatorList)
local ld, lx, ln, ls, lst, l, xx, i, j
set {ld, lx, ln, ls} to {theDisplayList, theIdxList, theNameList, theSeparatorList}
set {l, lst} to {{}, {1}}
if labelView then
repeat with i from 1 to 9
set end of l to {i & " " & ( item (ld's item i) of ln) as string , item (ld's item i) of lx}
end repeat
else
set end of l to {( item (ld's item i) of ln) as string , item (ld's item i) of lx}
end repeat
end if
repeat with j from 2 to 4
set end of lst to (ls's item (j - 1)) + (lst's item (j - 1)) + 1
end repeat
set beginning of l to hd1
set l to my insertItemInList({hd2}, l, lst's item 2)
set l to my insertItemInList({hd3}, l, lst's item 3)
set l to my insertItemInList({hd4}, l, lst's item 4)
return l
end prepareList
on selectActionFrList(theFullList)
local l, ln, lu, theItemChosen, theChoiceIdx, theChoice, theDestDB
local vid
set l to theFullList
set {ln, lu} to my split2itemList(l)
set theItemChosen to choose from list ln with prompt "Switch To"
set theChoiceIdx to my indexOfOneItem(theItemChosen, ln)
set theChoice to item theChoiceIdx of lu
if labelView then
if ( character 1 of (theItemChosen as string )) is in "123456789" then
my SendShortCut(theChoice)
else
set theDestDB to database id theChoice
if item 2 of ( item theChoice of dbs) is "" then
set db to ( get record with uuid item 1 of ( item theChoice of dbs))
set the root of think window 1 to db
activate think window 1
else
set root of think window 1 to get record with uuid ( item 2 of ( item theChoice of dbs))
set selection of think window 1 to {( item 3 of ( item theChoice of dbs))}
if ( item 4 of ( item theChoice of dbs)) is not "" then set search query of viewer window 1 to ( item 4 of ( item theChoice of dbs))
end if
end if
else
if theChoiceIdx ≤ 13 then
else if theChoiceIdx ≥ 15 then
else
end if
end if
end if
else
else
end if
end if
end tell
end selectActionFrList
on sortLOLByItemIdex(theList, i)
set theIndexList to {}
set theSortedList to {}
repeat (length of theList) times
set theLowItem to ""
repeat with a from 1 to (length of theList)
if a is not in theIndexList then
set theCurrentItem to item a of theList
if theLowItem is "" then
set theLowItem to theCurrentItem
set theLowItemIndex to a
else if ( item i of theCurrentItem) comes before ( item i of theLowItem) then
end if
end if
end repeat
set end of theSortedList to theLowItem
set end of theIndexList to theLowItemIndex
end repeat
return theSortedList
end tell
end sortLOLByItemIdex
on splitList(theList, firstNItemToKeep)
set list1 to {}
set list2 to {}
-- set a to ((length of theList's item 1) - firstNItemToKeep) as integer
set a to firstNItemToKeep
repeat with i from 1 to length of theList
set end of list1 to items 1 thru a of ( item i of theList)
set end of list2 to items (a + 1) thru -1 of ( item i of theList)
end repeat
return {list1, list2}
end splitList
on SendShortCut(idx)
if idx is 1 then
delay 0.05
keystroke 1 using { option down , command down }
else if idx is 2 then
delay 0.05
keystroke 2 using { option down , command down }
else if idx is 3 then
delay 0.05
keystroke 3 using { option down , command down }
else if idx is 4 then
delay 0.05
keystroke 4 using { option down , command down }
else if idx is 5 then
delay 0.05
keystroke 1 using { command down }
else if idx is 6 then
delay 0.05
keystroke 2 using { command down }
else if idx is 7 then
delay 0.05
keystroke 3 using { command down }
else if idx is 8 then
delay 0.05
keystroke 4 using { command down }
else if idx is 9 then
delay 0.05
keystroke 5 using { command down }
else if idx is 10 then
delay 0.05
keystroke 6 using { command down }
else if idx is 11 then
delay 0.05
keystroke 7 using { command down }
else if idx is 12 then
delay 0.05
keystroke 1 using { control down }
else if idx is 13 then
delay 0.05
keystroke 2 using { control down }
else if idx is 14 then
delay 0.05
keystroke 3 using { control down }
else if idx is 15 then
delay 0.05
keystroke 4 using { control down }
else if idx is 16 then
delay 0.05
keystroke 5 using { control down }
else if idx is 17 then
delay 0.05
keystroke "p" using { control down }
else if idx is 18 then
delay 0.05
keystroke 6 using { control down }
else if idx is 19 then
delay 0.05
keystroke 7 using { control down }
else if idx is 20 then
delay 0.05
keystroke 8 using { control down }
else if idx is 21 then
delay 0.05
keystroke 9 using { control down }
else if idx is 22 then
delay 0.05
keystroke "s" using { control down }
else if idx is 23 then
delay 0.05
keystroke "u" using { control down }
else if idx is 24 then
delay 0.05
keystroke "d" using { control down , option down , command down }
end if
end tell
end SendShortCut
on setWrappingLine(str, sym, len, align)
set a to count str
set ul to "" as string
set ur to "" as string
if len < a then
repeat 3 times
set ul to ul & sym
end repeat
set w to ul & str & ul
else
if align is "C" then
set c to (len - a) / 2 - ((len - a) / 2 mod 1)
repeat c times
set ul to ul & sym
end repeat
else if align is "L" then
set c to len - a - 3
repeat 3 times
set ul to ul & sym
end repeat
repeat c times
set ur to ur & sym
end repeat
set w to ul & str & ur
end if
end if
return w
end setWrappingLine
on insertItemInList(theItem, theList, thePosition)
-- cannot insert lol into beginning or last of a list
--source https://developer.apple.com/library/archive/documentation/LanguagesUtilities/Conceptual/MacAutomationScriptingGuide/ManipulateListsofItems.html
set theListCount to length of theList
if thePosition is 0 then
return false
else if thePosition is less than 0 then
if (thePosition * -1) is greater than theListCount + 1 then return false
else
if thePosition is greater than theListCount + 1 then return false
end if
if (thePosition * -1) is theListCount + 1 then
set beginning of theList to theItem
else
set theList to reverse of theList
set thePosition to (thePosition * -1)
if thePosition is 1 then
else if thePosition is (theListCount + 1) then
set end of theList to theItem
else
set theList to ( items 1 thru (thePosition - 1) of theList) & theItem & ( items thePosition thru -1 of theList)
end if
end if
else
else
end if
end if
return theList
end insertItemInList
on split2itemList(theList)
set list1 to {}
set list2 to {}
set end of list1 to item 1 of ( item i of theList)
set end of list2 to item 2 of ( item i of theList)
end repeat
end split2itemList
on indexOfOneItem(theItem, theList)
-- credits Emmanuel Levy
set {oTIDs, AppleScript's text item delimiters} to {AppleScript's text item delimiters, return}
set theList to return & theList & return
set AppleScript's text item delimiters to oTIDs
try
-1 + ( count ( paragraphs of ( text 1 thru ( offset of (return & theItem & return) in theList) of theList)))
on error
0
end try
end indexOfOneItem
on lolLookup(lookupVal, lookUpPos, getValPos, theList)
--only for list of list with more than 1 items
local i, j, k
set j to lookUpPos
set k to getValPos
if ( item j of item i of theList) is equal to lookupVal then return {i, item k of item i of theList, item i of theList}
end repeat
return {0, {}, {}}
end lolLookup
on firstN(n, s)
return text from character 1 to character n of s
end firstN
This is another script, I execute it when I'm on Safari ( It saves window URLs to DevonThink3)
Again, I have to execute it twice in order to work.
Here, I use Keyboard sequence.
property pURL : ""
property pName : ""
set the date_stamp to ((the current date) as string)
set NoteTitle to "URL List from Safari Tabs on " & the date_stamp
tell application "Safari"
set pURL to URL of current tab of window 1
set pName to name of current tab of window 1
end tell
tell application "DEVONthink 3"
create record with {name:pName, URL:pURL, type:bookmark}
end tell
