Every so often after waking up from sleep, the software escape key shows on the BTT touchbar even though it shouldn't show up on the MacBook Pro 16 inch model. This doesn't reproduce every time after sleep; however, it usually shows after its been sleeping for some time, not just opening and closing it for a minute.
MacBook Pro 16 inch touch bar
Type of Mac: MacBook Pro 2019 16 inch (MacBookPro16,1)
I have the exact same issue. I haven't been able to determine how to 100% consistently reproduce it, but it usually happens when the machine has been sleeping for more than a few hours. Then, restarting BTT is the only way I can figure out to get rid of the unwanted escape button.
