Open up Python and type in your JSON as a dictionary:
dictionary = {
"BTTTouchBarButtonName": "Button",
"BTTTriggerConfig": {
"BTTTouchBarFontColor": "110.000000, 193.000000, 56.000000, 255.000000"
Then simply json.dumps
it twice:
import json
output = json.dumps(json.dumps(dictionary))
print(output)
You will see the output is the following:
"{\"BTTTouchBarButtonName\": \"Latest\", \"BTTTriggerConfig\": {\"BTTTouchBarFontColor\": \"110.000000, 193.000000, 56.000000, 255.000000\"}}"
Saves quite a bit of time if you are working with large layout modifications, and ensures you don't make small mistakes. Technique works for Python 2 (system-installed) and Python 3.
