Doubleclick Window Titlebar Glitch
Hi there,
There seems to be an error with either macOS or how BetterTouchTool handles “title bar” elements.
My setup for the action:
Trigger Section: Automations & Named & Other Triggers
Trigger: Doubleclick Window Titlebar
Action: Maximize Window
What this now does is if I e.g. 1) right click, then right click again, or 2) right click and then left click something fast, it will do the action (maximise window).
For example, if I right click a folder twice in a Finder window. First click opens the right click menu, then the second click does a right click on the edge of that window, which seemingly must share the same element as the “title bar” element.
Why when I do a right click it acts like a left click? I’m not sure. Maybe the “Doubleclick” allows for both left or right clicks.
P.S. I have also noticed the description of “Other Configuration” (when selecting any trigger on Automations & Named & Other Triggers) it has a double space in the description: “Select and configure special triggers that do not  fit into any other category”
  • macOS version: macOS Tahoe 26.3 (25D125)
  • BetterTouchTool version: 6.475 (latest as of this post)
Can you check whether this works for you in 6.484?
Hey there!
It seems to be fixed now. FYI I have updated to 6.526 and it doesn’t do the behaviour that I reported! Thank you so much.
