Hello All,
Double tapping with 1 finger to select the lines not working in magic mouse.
Please help to configure.
Regards,
Suresh
Hello All,
Regards,
Suresh
Using the Right blue Plus add two left click actions.
Afaik you can't do this for now.
@vs.suresh your config is correct. Just make sure you haven't accidentally disabled this setting (which is on by default):
Also make sure no other fingers are touching the touch area of the mouse when you do a single finger tap
Ah, learned something new about BTT again! Amazing!
