i mean currently i can press ctrl + opt + mouse move
to move the window, i know its related active by BTT because when i close the app i cant use the gesture anymore.
so is there any other hidden gestures ? & how to enable/disable them if any ?
thank you so much for this, i was actually trying to mimic GitHub - kentywang/Origami: 👩💻 Pinch to resize any window, thanks again
is it possible for the cursor move to have an option to move the active window instead of the window under cursor ?
