Discussion: BetterTouchTool Launcher / Spotlight Replacement (very much work in progress)
strange, I can't get it to cut off. Which version of BTT are you on?
OOOH I found out how to reproduce it -- if you simply launch the clipboard AFTER brining up the Launcher, it opens up WITHOUT any cut-offs. BUT if you launch the Launcher's clipboard directly via a trigger (with the newly implemented function "Open Launcher item immediately"), the cut-off appears.
great! can you check whether 6.491 fixes this?
@yougotwill I hope 6.491 also fixes your plugins!
By the way if anybody wants my tetris like fallingblocks or pong plugins they are here (drop them into BTT or in the Launcher Setting's plugin section):
LauncherPong.swift (15.4 KB)
LauncherFallingBlocks.swift (20.4 KB)
6.491 doesn't seem to be detected by the app's autoupdate yet. Will test it as soon as I get to update to 6.491!
you need to use "check for alpha version updates", it should available there now
By the way, one feature I have not mentioned yet:
The launcher can also be used as a temporary file shelf. If you start dragging a file in Finder (can also be other things like urls, pictures, links etc.) and then open the launcher, it allows you to drop these onto it.
I can confirm, the clipboard UI cut-off issue is fixed in 6.492! Thanks for the speedy fix, @Andreas_Hegenberg
Wow you've even built a file shelf inside the launcher -- at this rate, I can get rid of Monarch and Droppy altogether :rofl:
Hi Andreas,
with BTT 6.492 I got this problem. Opening a URL with the variable {BTTLaucherLastPromptAfterKeyword} does not work anymore.
This also affects the leo.org floating menu.
Ah sorry, that got renamed to BTTLauncherPromptInputWithoutKeyword a while ago for consistency with some other BTT stuff
Just noticed a curious issue -- Launcher can't seem to be able to search for macOS' native Passwords app. Even if I click into "Apps (both running apps & installed apps enabled", from the list, the Passwords app is nowhere to be found :thinking:
Ah I'll fix that. It's because passwords is not a real app and BTT filters those out by default
I just installed the update that includes this. Fantastic!
A request I'd like to make: I can't seem to search for my shortcut actions from the Shortcuts app. Is there a way to include those? I know they can be searched using Spotlight (at least if you explicitly choose the option in the shortcut).
Is it feasible to allow copy or move files to the shelf?
Ah yeah I had already used a shortcuts plugin internally that worked well for me, I'm now making it available for everybody in 6.496 (uploading).
You can either just open the item and browser your shortcuts or e.g. type
shortcuts shortcutname shortcutinput
Just wanted to report that, similar to the Passwords app not showing up in the Launcher issue earlier (but later fixed in new updates), the Macabolic app is somehow not showing up as well (despite I'm already on BTT v6.496).
I have a small feature request that i think would make me switch completely from the now bloated Raycast to this BTT search solution
I would love if there was some scratchpad feature similar to raycast quick notes, to write down quick stuff and keep a few quick notes handy with a simplle kb shortcut. No need for extra fancy stuff, just regular text, possibly lists. Of couse full MD support would be the best, but not needed
Also, I think the clipboard manager looks too big on my screen, so i resized it, bui when open it back up, it seems to reset its size to the default.
Love the new shelf feature, this one feature replaces entire apps!
Some more feedback-- system settings search does not seem to work. Searching for "menu bar" in spotlight shows its settings. BTT launcher:
Also currency conversions look like they require specific wording. For example, if I search for "1000 baht in dollars" it says it's $1000, which is very wrong. "1000 thai baht" does work. This may be a soulver issue outside of your control, though.
And for one last bit of feedback, typing in the launcher feels laggy and unresponsive. My guess is this is because it tries to instantly recalculate its results with each button press. Maybe adding some sort of short delay there would make it feel better?
Edit: OK, one more potential feature "time in stockholm". IE what time is it in X city or country right now.
Edit: I found it: Launcher Plugins | BetterTouchTool Documentation
Is there any API reference yet for Launcher Plugins apart from the AI assistants ? I'm looking at your Pong and Tetris plugins, which are helpful too.
I can't seem to get plugins to work? I dragged your Tetris demo on the Launcher Setting's plugin section. It asked 2 times if I wanted to compile it, then had another confirmation. Now in the Launcher settings, it shows that it's installed and I can change the order in the settings. But it doesn't show up anywhere in the launcher. What do I need to do?
I had the same experience with installing the basic example.
I'm on Sequoia 15.7.5 and BTT 6.497.
