Hey @Andreas_Hegenberg, is there a way to achieve the same for other "sections"/items? I've asked AI to generate me a plugin which allows to search MS Edge bookmarks, but fuzzy search doesn't work to find my bookmarks. Here's an example:
AI made some changes to the plugin, but it is not working. I cannot verify if the changes are correct.
It partially works only when the plugin is configured to "Always Show - Always shows, even while typing." - the bookmarks are shown but not all matches are not at the top despite that the plugin is at the top of the list with -5200
@xidiot I think I misunderstood because this should already be supported. Does your extension contain private data? Otherwise you could post it then I can check it. Setting the visibility of the extension to "Prompt Match" should do the trick.
yep it should work (if set to „prompt match“ in the settings)! I‘ll have a look at your plugin later today and check if there is an issue with BTT or with the plugin!
I think I found the mismatch, my description on how to create plugins was not clear enough for the matching priority and the AI misinterpreted the instructions. (And honestly the AI's interpretation makes more sense than what I had in mind).
So now I adapted the logic in 6.334, the AI generated code should now behave correctly.
currently there is no way to disable this, I'll add an option with the next release! (even after all the years it is still funny that for any given feature there is always one group of users that prefers behavior a and the other group of users that prefers behavior b )
It shows up somewhat above the desired position. I had worked out the y% adjustment so that it would appear basically in the default position for Spotlight.
So on normal, for comparison, the text entry for BTT's launcher would show up in the same spot as Spotlight. But on the messed up launch, it's about this much higher:
Hi all,
Launcher is a great addtion to BTT. I am trying to replace Raycast with it.
One question I have is: How can I show hidden files in the built-in File Browser?
if i open the launcher and start typing, there is a noticeable lag. however, if i remove what i typed and type the same query again, there is no lag. i should also mention that the problem doesn't fix by waiting after opening the launcher (e.g. opening the launcher, waiting for 10 seconds, then start typing) and the lag disappears only if i type a query, remove it, and type again (even if i type another query, there won't be any lags).
i'm on a macbook air m1 (16gb memory), mac os 26.5.1 and btt v2026071312
Andreas, "cloud admin" as a search string doesn't work again. My bookmark is not shown, and again if I search for "admin", pgadmin (the app) is before a bookmark containing that string.
