Triggers seem to disappear (from both old and new UI's) when trying to reorder items and subitems in new UI. But the trigger is not gone and can still be activated by URL with its GUID.
I was looking for a way to demote the first item and make the second item first. I had hoped that the new UI enabled this.
Don't think it's relevant, but "Other"
I can't screenshot the lack of a thing
- Type of Mac:
Macbook Pro 2017 - macOS version:
Mojave - BetterTouchTool version:
3.071
(check)
