The issue is when activating button 4 when Framer is active, it doesn't do anything even though it is disabled in the specific app config. The button 3 works because I have not set up any config in Framer.
If i delete the button 4 config, the global button 4 config now works in Framer.
So I think the issue is the BTT "disable selected trigger" function doesn't fully "disable" it. Is there a setting I missed enabling?
I'm not sure if this affects Normal Mouse configs only.
This is expected and unfortunately can not be changed for legacy reasons. (A disabled mouse or keyboard shortcut in a specific app has historically been used in BTT to use the system default functionality in that specific app)
You could e.g. move the disabled triggers to a separate preset and disable that.
Another thing I noticed is that if I enable both the app-specific and the global configs, it activates the app-specific action (which I think is expected) but I don't get the "conflicting menu" to appear. Why is that? How will I know anything if I have both enabled or if one is disabled and the other one is enabled (for example in this scenario where I was not aware of it) that BTT is capturing/prioritizing the app-specific config over the global one? Hmm, maybe it is designed that way? I think maybe hints similar to the conflicting menu helps with how I navigate/use BTT. Idk
app specific always beats global, so no conflict menu will appear. This allows you to have some global stuff configured but override it for specific apps.
