Disable Shift. Control
Can I disable panel changes when I click "CapsLock Shift, FN, control, parameter, command"?
I am constantly only in the panel where I see " time, date, weather, reminders. And when I work in some application and I need to click on one of the listed keys, the panel is reset to minimized mode.
Can I disable these keys? Or can I make a permanently enabled panel with the time and date?
I write through a translator, I hope you will understand.
That shouldn't be happening, which app are you using?
Photoshop, Telegram
what shows up when you press shift and others?
(⌘⇧6 to screenshot the touchbar)
Imprint | Privacy Policy
