Delay Next Action and Restore Layout
Delay next action both blocking and non blocking ignore positional placement. When placed after an Apple Shortcut, the delay is taken before running the Apple Shortcut.
The Restore Layout also seems to run before the previous actions have finished, even with a delay next action (both blocking and non blocking). Thus windows, for instance, are not able to load before restoring layout, rendering the delay or restore functionality futile unless run as a separate stand-alone keyboard shortcut.
Using Apple Shortcuts seems to delay properly when opening a series of windows and programs better than BTT, thus integration is more reliable, but still have to separate restore layout functionality into separate keyboard shortcut because it will not function properly in sequence.
Mac Studio
Ventura 13.2.1
BetterTouchTool Version 4.062
