bnsena
August 25, 2019, 7:33pm
1
What happens when I drag a window to the edge of the screen is nothing happens. It won't resize anymore. Doesn't matter how many times I restart better touch tool or my computer.
Type of Mac: MacBook Pro (15-inch, 2018)
macOS version: 10.15 Beta
BetterTouchTool version: 2.716 (1025)
maybe you disabled window sleeping in the BTT preferences?
bnsena
August 25, 2019, 7:42pm
3
I don't think so. Here is a screenshot:
possibly try removing BTT from system preferences -> security and privacy -> privacy -> accessibility, then add it back.
Is your license correctly activated? (is it shown in the about screen in BTT?)
Also, is BTT possibly deactivated? (click menubar icon, does it say disabled somewhere?)
bnsena
August 25, 2019, 9:16pm
5
I don't have the newest version as it only upgrades for two years. Do you think that is the issue?
Here are the screenshots from what you suggested.
bnsena
August 25, 2019, 9:17pm
6
I did remove it from the privacy section and re add it.. nothing happened there.
Benjamin
bnsena
August 28, 2019, 11:46pm
7
It seems to work with the better touch windows.. but not others...
there hasn’t been a change in BTT that could cause this.
Have you already tried to restart your machine? Did you recently install some new software that could conflict with BTT?
