A use the customVariables to use in the conditional groups, but I no longer works, yet it used to.
I have this code, and it was working well.
set_persistent_string_variable "customVariable1" to "CONTROL_STRIP_MEDIUM"
end tell
It just shows the variable as empty.
edit:
I also tried it in Javascript, just for sure. Did not work.
- Type of Mac: MacBook Pro (13-inch, 2017, Four Thunderbolt 3 Ports)
- macOS version: macOS Mojave version 10.14 (18A389)
- BetterTouchTool version: 2.717
