Custom snap areas issues
After setting a custom snap area, I cannot change line thickness or put checks on the fields like "Make Snap Area Invisible". The only thing I can do is changing colors of the fill and outline.
One more big issue is that the custom snap areas can't be deleted. When I click the X button, it asks if I'm sure, and when I click yes, nothing happens.
3.286
P.S. I found a workaround: "Reset Snap Areas" button in the settings.
  • Type of Mac:
  • macOS version:
  • BetterTouchTool version: (please post the exact version - not just "the latest one")
Thank you! Should be fixed in 3.300 alpha (online in 5 min)
