Custom settings for Website
is there a way to change keyboard behaviour on a per-website basis?
i use a tool called fibery. its a browser based DB tool. i would like to create shortcuts for this website alone.
one example is "cmd+L" which triggers the browser search bar. but in this tool its supposed to add a link. was wondering if i can add a BTT setup where i can use another shortcut or "disable" the browser shortcuts if i am on this website
I assume this can be done with a CAG. If window name contains "fibery", then ⌘+L does something else. In your case "add a link", if you can access it.
