Is it possible in BTT to create a search field with custom search engines? For example, I would enter “g something”, “w something”, or “a something”, and based on the first letter, the “something” part would be sent to Google, Wikipedia, or Amazon.
I know that browsers have these features built in. I could probably also create an Apple Shortcut that works the same way. But in BTT I would like more control, such as the ability to open the URL in a non-default application, etc.
I like the user interface of the “Choose Action From List / Prompt” function, but it probably won’t work for this.
Actually you can use this interface. Here is an example. It makes use of the "Use First Word To Filter & Save Rest Of Input To Variable BTTPromptInput"
NOTE unfortunately something recent must have introduced a little timing issue for this function, which is why this example requires BTT 6.037 to work (uploading now).
