Hi there,
Maybe a bug in combination with Macos Sonoma (latest developer beta) Every time when i move a window, the notch is hidden (the resolution gets scaled). If I then restart Better Touch Tool, the notch becomes visible again and the resolution gets back to normal.
Possible a feature but i cant find a way to turn it off then...
I think i solved the problem by changing te resolution and then back to the resolution i use (strange).
Greetz Dino
Note:
- Type of Mac:
- macOS version:
