I've tested out the new Custom MenuBar Icon control. Works Amazing - but the icon it puts there is just blank. clickable, but totally blank.
Edit: If you look between the Airplay and Volume button you'll see a blank space.
Type of Mac: Mac Mini Late 2014
macOS version: 10.15.1
BetterTouchTool version: version 3.336 (1544)
Judging by all the other bugs I'm seeing with this latest update - this is not very important - you can whack it to the back somewhere and get to it when you get a chance.
I've created several MenuBar icons without any troubles using BTT 3.333. Can you successfully set the icon when you create the MenuBar Action Configuration?
now that I've uninstalled/deleted extraneous BTT files and reinstalled via Setapp, I can't pick a custom menubar icon (the picker doesn't pop up). Non-setapp version works fine. Anything I can check?
