What is the easiest way to move a trigger from the Master preset to another one. "Paste JSON from Clipboard" seems to paste into the Master preset only.
There's a trick at this point that looks as follows: temporary change your master preset to the one that you want to have the triggers (target one) and just do CMD+C -> CMD+V on desired actions. It'll copy them to the current master preset, then you'd need to delete duplicated unnecessary entries and swap your master preset back to the one you initially had selected.
Thanks for the reply. I wondered if there were a more direct method, but this works.
