Control Strip Button not there after wake from sleep
Is this a known issue?
I have the option Restart BetterTouchTool after Wake From Sleep turned off. Is that a workaround I should use for this?
BetterTouchToolDebug.zip (2.2 MB)
is it replaced by some other app? (unfortunately the system decides about the priority of items in the control strip... BTT can just ask to be put there)
In tonight's case it was replaced by the media button, yes. I'll pay attention to it and report back.
Just reproduced this a few times, @Andreas_Hegenberg. Nothing should've replaced my Control Strip Touch Bar button. I tried enabling the restart after waking from sleep, but it didn't help. Logs attached. Is this a bug?
So basically to get my button back is to restart BetterTouchTool manually.
BetterTouchToolDebug.zip (1.8 MB)
