Hi there,
I have enabled these:
And the command pluginkit -mAD -p com.apple.FinderSync -vvv shows:
And I still get this warning and the context menu does not show up in finder. Restart didn’t help:
Any ideas what I could try? Thanks
Hi there,
which version of BTT re you running?
I updated to the latest version and it worked. Thanks for the quick reminder. ![]()
However, just a short info. I still get this:
Also, the changes to the context menu are not directly applied, even though I pressed the finish button. Restarting BTT also didn’t help. When I quit BTT, the context menus are still visible. I will try a reboot later.
And it also seems like the SFSymbols are not .scaleAspectFit/Fill, but instead are stretched:
Icon in the context menu:
Icon in SFSymbols app:
that button will always show ![]()
Refreshing should often work automatically but in some cases you might need to restart Finder (opt+right-click the finder icon => relaunch)
Unfortunately Finder doesn’t honor the SFSymbol scaling settings.
Thanks for the info. I just rebooted my machine. Unfortunately, the context menu is gone again. Restarting Finder & BTT didn’t help. Here is an export of the preset:
exported_triggers.bttpreset (16.4 KB)
It is still rather buggy for me. Sometimes the context menu entry is there, sometimes not. Desipite having defined an icon for the context menu entry, it does not show. Can we expect any fix soon? I am on Version 5.670.
