After I updated to the new BTT ui, my conditional activation groups stopped working, in that none of the keyboard shortcuts work.
If I move the shortcuts under "all apps", they work again.
Keyboard
- Type of Mac: MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports)
- macOS version: Mojave 10.14.4 (18E226)
- BetterTouchTool version: 3.105
An example Cond. Activation group that doesn't work:
This note should be at the top!
