Condition not working
When putting this condition, the condition on the right reads it, but on the left does not reflect it. It works with BetterTouch tool if I put it in there, but not apps outside the BTT.... So some background thing maybe, but even while it shows up at the red horizontal line though.....
WhatsApp (capital A)
I did that same problem. Just typo for the print screen. I double try with video tomorrow morning.
Hovered App WhatsApp, condition is not WhatsApp, currently true...... That is incorrect.
It looks like some pretty special thing in WhatsApp that I haven't seen before.
The app name contains an invisible unicode character at the beginning [U+200E]WhatsApp, thus any equality checks will fail.
The easiest workaround is to switch the condition to "Contains" or "Ends With"
Tanx for your quick reply and how quickly you found the issue.
The thing is I DON'T want it to work in whatsapp, but there is no does not contain....
The problem is that the free scrolling resets to the start point when I click before it comes to a stop in whatsapp, therefore I want it off there.
I wrote about that issue here, but this condition would be a warkaround.
EDIT: None of the following is true works off course!
