When BTT is enabled I cannot delete files in finder using the standard Command + Delete keys. When I disable BTT it works as expected.
It also doesn't work when created a shortcut with BTT tool, I just get a standard 'tik' Mac sound when I press those keys.
Any idea what the issue is? I believe it was working but not anymore no idea why...
Running M1 Max 16" latest version.
Cheers,
Matt
