Hi !
I would like to know if it is possible to add this feature.
When we have option to choose color, could you add a variable as choice ?
So we can change multiple items color at once.
Thanks for your great tool
please post a more specific example, are you talking about Touch Bar, Floating Menus, Custom Menubar Icons, Stream Deck… ?
yes sorry, it's for Floating Menus and menu items
I can do this if i use web view/html item with html and css variable for color, and then change color by the trigger Assign/set value for variable.
But i prefer to use standard items for simple menu and i dont find a simple way to do the same
If you need to do it via a variable you'd need to define the whole menu using a script:
https://docs.folivora.ai/docs/1108_simple_format.html
However do you know you can select & edit multiple items at the same time?
5.243 alpha now also allows to change the formatting of text for multiple items at the same time.
Ok, good point, i forget it, i'm going to try later with scripting the all menu.
I was aware of select & edit multiple items at the same time, but i had this problem with the text that you just resolve
"Multi Selection Dummy Text..." that you add is wonderfull, just need to select this last phrase before changing color, great ! Thanks
