Close Window Under Cursor During Mission Control
I frequently use the close window under cursor while in mission control. I hover over a window then two finger tap my trackpad and it typically works to close windows but if i have 10 windows open it is common for it to only work on 8 - 9 of the windows. Some apps, such as adobe acrobat, never close (which could be a different issue IMO).
Affected input device: Using Macbook Trackpad
not necessary
  • Type of Mac: Macbook Air
  • macOS version: Tahoe 26.0.1 (This issue existed even on the older MacOS version though)
  • BetterTouchTool version: 5.722
