Hello,
Just noticed a problem after latest update (including alpha).
I use Key Sequence to paste predetermined text, and now this text stays in the clipboard. Before the update it did not replace my previous clipboard, I could paste it even after using the Key Sequence.
Example of my paste action:
- Type of Mac: iMac (Retina 5K, 27-inch, 2020)
- macOS version: Catalina 10.15.7
- BetterTouchTool version: BetterTouchTool 4.011 (2225)
Best,
Grigory
could you check whether this works with 4.013 alpha? (uploading right now, will be online in 10 minutes via "check for alpha version updates")
Works like a charm, thank you very much.
Have a great weekend.
Hello,
In the version 4.019 (2236), Key Sequence paste is behaving ok in web browsers and text edits, but started to behave wired in graphic software like Adobe Illustrator and Photoshop.
Sometimes it works okay, sometimes it just removes the original text and does not past any new, and sometimes it pastes a clipboard text from cmd+c before.
Hey,
version 4.023 (2240) all works good.
