Clipboard management : Renaming entries
the novel clipboard manager is really nice and powerful but it would be needed to be able to rename the entry (when you want to keep it). Web links, text portions, etc, emails, would really benefit from this.
Thanks !
Franck
you mean tagging them - that is planned! You can however already edit the items in the clipboard manager and write whatever you'd need there
不是给他们打标签,而是更改显示的内容,比如这个代码片段,列表中只显示了“/**” 我希望显示一个对这个片段的自定义的描述。
当然,打标签是另外一个不错的功能,不过标签和分组有一些重复,都属于内容分类,只是分类维度不同,当然如果这不是很复杂支持标签也很不错。毕竟这在内容管理上很常见
Not tagging them, but changing the displayed content. For example, in this code snippet, only "/**" is displayed in the list. I hope to display a custom description of this snippet.
Of course, tagging is another good function. However, tags and grouping have some repetitions. They both belong to content classification, but the classification dimensions are different. Of course, if it is not very complicated, supporting tags is also very good. After all, this is very common in content management.
