Clipboard key bindings affected by lastly focused window
I’d like to use some key bindings on clipboard.
But the keys you can use on clipboard are affected by the window lastly focused with “Keep clipboard manager floating on top…” option checked.
Say there’re two applications, Chrome and Terminal, and I apply Ctrl-N to go up only to the former.
You can use the key on clipboard only when it’s open on top of Chrome.
I therefore unchecked the option, but in that case the window isn’t focused after escaping or deleting clipboard (Works perfectly when I select texts though).
I attempted to work it out, but couldn’t figure out how.
I appreciate if you give me some advice.
