Hi! I am wondering how to change the weather from fahrenheit to celsius unit? Thank you!
If what you are using is a weather widget, you can go to 'Widget Specific' and change it from Fahrenheit to Celcius.
If you have coding to make ur weather widget, im sure there will be something there.
thanks
