Capture Screenshot (configurable) issues
Hello! I'm a bit stuck on the mechanics of the screenshot action. I've changed it to configurable and have my only active action as capture current screen instead of window. My issue is that when I screenshot something it goes to my background image instead of, for example, the google search image I want to take a screenshot of. I just downloaded BTT yesterday, so help would be appreciated with this issue!
BTT needs screen recording permissions in System Settings => Privacy & Security in order to capture anything but the background
Thank you for the help! :slight_smile:
