When trying to directly paste my script directly into the window, using the Old Configurator UI, it is unable to either copy or paste using the keyboard shortcuts. Mouse right clicks are registered.
In order to use the keyboard shortcuts, I have to open the new configurator UI, switch back to the Old UI, and then it works as normal to use the keyboard shortcut.
Macbook Pro keyboard and wireless apple keyboard
- Type of Mac: Macbook Pro Retina, 15in, Mid 2015
- macOS version: 10.14.5
- BetterTouchTool version: 2.856
Need to open the new UI window in the background and then go back to Old UI to copy and paste.
Additional related issues: Had scripts that worked as intended when using Script Editor. When ran using BTT, it failed and couldn't. I had an idea of what the issue may be, possibly interfering with "System Events" commands. I rewrote my script numerous times to isolate the section, getting around the potential unintended usage of "System Events", and found a work around for it to run in BTT that seemed to indicate an unwanted execution of "System Events" within my script, when BTT ran my script.
