I have an M2 MacBook Pro running Ventura 13.1. Icannot get the BTT icon onto the Touch Bar so I can switch between the Mac Control Strip and the BTT one. At the moment the only thing that works is going into settings and ticking/unticking the Show macOS Control Strip box. The Show BetterTouchTool Icon in Control Strip does nothing. I saw an earlier report of something similar in Monterey 12.2 but that was solved by an update. I was hopeful for the latest update to BTT but nothing changed. I posted this on the forum but have had no replies so am reporting it as a bug.
MacBook Pro Touch Bar
- Type of Mac: M2 MacBook Pro
- macOS version: Ventura 13.1
- BetterTouchTool version: (please post the exact version - not just "the latest one"). 4.017
The only way I can access the BTT icons in the Control Strip is to go into Settings and deselect Show macOS Control Strip. This is a new MacBook I am building from clean so there is no real legacy stuff on there to get in the way.
