So because I have a windows style keyboard I use https://folivora.ai/ (better touch tool) to remap key combinations.
Unfortunately even after pointing better touch tool at /usr/local/bin/alacritty none of the keys are remapped...
This is for things like mapping Command C => Ctrl+C.
Not sure if this is an alacritty issue or a better touch tool issue.
- Type of Mac: mac mini
- macOS version: mojave
- BetterTouchTool version: 2.426
already tried restarting.
