Bug?: l⌘ + r⌘ + letter is not triggered
The shortcut combination in the title triggers either l⌘ + letter or r⌘ + letter. If something is set up in BTT.
Shouldn't l⌘ + r⌘ + letter be a separate trigger?
you mean like this?
It seems to work ok here - did maybe secure input get activated by some application (click BTT menubar icon to see secure input state), With secure input enabled BTT currently can't differentiate left/right modifiers (on my TODO list to find a workaround)
No "secure input" :slightly_smiling_face:
But the error was here. I have set this up
Instead of this
This apparently means that if l⌘ and r⌘ triggers the same, it doesn't work. No problem, I just have to know :slightly_smiling_face:
Edit: Ah, but it might be a problem for others because it's not entirely logical in my humble opinion :slightly_smiling_face:
Ah I see - non differentiating shortcuts are always evaluated first to prevent other issues.
I have been thinking about auto-enabling the "differentiate left/right modifiers" option, the code is now pretty stable (apart from the secure input thing) - maybe this makes sense now.
Then leave it like that. It's all good, you just have to know it. Now you know, thanks to this conversation. :slightly_smiling_face:
