Key repeat does not work here.
It works if this action is deactivated.
But this way you lose the "J". J should only be Arrow left when the mouse is over the menu bar.
Ah, could this have to do with J = J having "prevent recursive triggers" enabled and the two actions being linked? Too bad...
