Bug: Click Notch / Double-Click Notch
I have a floating menu that appears when I click inside the Notch.
Description of the bug:
  • I click inside Notch
  • The floating menu appears
  • The first time I click anywhere (a menu item of the floating menu, a finder item, etc) there is no action (the first click is not clicking)
  • The second click works well
The bug is the same for the action Double-Click Notch.
There is no bug with the action Right-Click Notch.
  • Macbook Pro 16 2021 M1Max 32 GB
  • Ventura 13.5.2
  • BetterTouchTool version 4.262
Can you check whether this is fixed in 4.264?
Click Notch is fixed in 4.264.
Double-Click Notch is still not working in 4.264.
Click Notch fixed in 4.264.
Double-Click Notch fixed in 4.265.
