Version: 4.074 (2292)
MacOS: 13.3 (22E252)
Mac: M1 Pro
Description:
I am having an issue where when I have stage manager settings enabled for respecting a gutter to not cover stage manager, it does not respect these settings. It is not respecting these settings when using the predefined window resizing settings such as "right third", "right 2 thirds", etc.
Desired Behavior:
In the past when the stage manager settings are enabled, when using settings such as "third right", the resizing would adjust left by the setting amount and did not cover stage manager.
- Type of Mac:
- macOS version:
