Hi, I am trying to create a workaround for iOS shortcuts not adding songs to a playlist when using the add to playlist function (it adds it to the iOS device, but not all others...). When you do this shortcut on Mac, it works fine.
I had an idea to press a shortcut on iOS, prompts to select a "tag"/playlist to add the song to, copy that value to the clipboard, and open the BTT Remote app so I can run a BTT trigger which passes a variable to my BTTTagSong AppleScript.
Not sure if there's a simpler way... I have keyboard shortcuts setup to use that script which work great on my Mac, but id like to be able to do this from my phone.
Thanks in advance!
