BTT-UI does not show up. To get the UI i have to remove/add BTT from the SysPrev/Accessibility-Settings each time (not sometimes as mentioned in the forum) i want to use the UI.
Even though the UI does not show up BTT is working as expected (but it makes it a bit difficult to change the shortcuts if needed).
- Type of Mac: MacBookPro18,1, Apple M1 Pro 32 GB RAM
- macOS version: macOS Monterey 12.0.1 (21A559)
- BetterTouchTool version: 3.624
there are not stack traces or crash-reports available.
i had the same behaviour on my prev. macbook-pro with touch-bar (2016) and macOS Catalina.
if i can help by providing any additional info/test - let me know. i really love BTT as it makes my work a lot more efficient. even though apple has discontinued touch bar
greetings
AndiY
