The bug:
BTT TouchBar will open up once after rebooting my mac, but once closed will not open again. BTT touchbar toggle button does appear, but custom buttons do not.
Affects:
MacBook Pro 2017 touchbar
- Type of Mac: MacBook Pro 2017
- macOS version: Mojave 10.14.2
- BetterTouchTool version: 2.683
Edit:
Discovered the problem. There's a setting under the general touchbar settings in BTT that hides the BTT touchbar if there are no actions to display. I have one button created that simply presses a keyboard shortcut (being ^ + ⌘ + [). I turned that setting off and now I can toggle the bar on and off like it's supposed to. My button shortcut doesn't work however.
