This started on Tuesday (March 17th). BTT would start using 100% CPU and freeze about a minute after launch (beachball when hovering over the app icon, Touch Bar not responding). Sometimes it would also disable the force click feature of the trackpad.
I have the latest alpha version installed 3.346 (1554). Restarting my Mac doesn't help. The only way to quit BTT in this situation is to kill the process + the relaunch process.
My device is a MacBook Pro (16-inch, 2019) running macOS 10.15.3.
what kind of actions do you have configured in BTT? It sounds like something is triggering itself in an endless loop, maybe a keyboard shortcut that has itself assigned as action?
Thanks Andreas for replying so fast. It's mostly just a bunch of Touch Bar stuff, like Spotify controls, safari shortcuts, launch WhatsApp, etc. I haven't changed anything before the problem started, I've been running the same configuration for months.
Attaching my preset file here in case that helps: Default.bttpreset (784.0 KB)
