BTT quits on clicking floating web view
Mac OS: latest
BTT: 2.504(842)
Since upgrading from 2.503, clicking on a floating web view causes BTT to quit.
Does this on all(3) of my views.
Are they triggering Apple Scripts? (There were many changes in regards to the apple script handling, maybe I forgot something). Could you check if there are crashlogs in the macOS console.app under "User Reports"?
Indeed they all trigger applescripts, and yes there are crash logs. Where do I send one?
The crash log mentions:
Application Specific Information:
*** Terminating app due to uncaught exception 'NSInvalidArgumentException', reason: '-[BTTActions runAppleScriptOnMainThread:withReply:]: unrecognized selector sent to instance 0x6000001ded20'
terminating with uncaught exception of type NSException
abort() called
Would be great if you could check v2.505 alpha I just uploaded
Works like a charm, tx
Imprint | Privacy Policy
