BTT Mobile Testflight Beta
Ever since I upgraded to iPadOS 26, I get those bubbles around all buttons, any way to get rid of them?
Liquid Glass is set to disabled on the buttons configuration:
i’m testing the mobile app - i don’t see a way to get back to the main menu after i selected this menu that lives on my desktop at all times.
you can swipe from the left edge to the right, or add an item to your menu and assign the action you need:
but i’d have to add that to my existing panel that is only for my mac desktop?
i tried swiping in all directions on the page from the screengrab above, but nothing got me out of that page. i would prefer not to have to add a new button to go back on an ipad to every menu that i’ve built - i was hoping to just be able to access all the menus that i’ve built as is.
weird, swiping should work - what kind of iPad do you currently test with?
The next version also allows to have items in a menu that are only visible on ios or only on macOS.
yup, older ipad. still has a home button and it tops out at ios 17
i might have one other ipad that is a model or 2 newer. thanks.
I'll check with some of mine tomorrow - it shouldn't really matter.
thank you
has inverted scrolling already been added maybe?
i got a new ipad with os26 and the same behavior was happening.
@Andreas_Hegenberg You’re probably already working on this, but the BTT Mobile beta has expired.
The BTT mobile app has expired. Can anyone suggest how to install the latest version? Thanks.
new version will come in a few days and then hopefully be the first app store release version as well
New version is now submitted to Testflight and should become available tomorrow. I have now implemented most features I had planned for the initial release. I need to do a few more bugfixes for special things like the webview, these will follow in the next few days. I hope I can start the App Store submission in about 1 week.
  • new predefined action "show keyboard input on connected ios device"
  • new "active app" tab in the BTT Mobile app which basically replicates the old BTT Remote functionality from 2012
  • new AI Chat tab that lets you use your BTT ai assistants
Back to BTT again after 2 months from a big surgery. Andreas, what you did last month is incredible. How dare fucking Apple not hire you till now?!! LEGEND.
A first release of BTT Mobile is now available via the App Store, but if you are on Testflight I'd recommend staying there for now as I'll push multiple bugfix updates soon.
